14 2500 all over road after replacing front end parts
Popovic77
Ohio
I replaced
Ball joints
Toe bar
Both ends of drag link
Track bar
Sway bar links
Both wheel bearings
Axle shaft u joints
All we’re replaced within the last four months
After replacing the ball joints, toe bar, and drag link the truck it hard to control and sways side to side on its own mostly after after 30 mph it gets worse with more speed, also if I hit a bump it will sway to one side or the other
Also another thing I noticed is the front springs aren’t sitting straight they have a bow to them I heard that was something to do with the axle being in the wrong angle would that be something to do with that?
Thanks for the input!
olyelr
Kewadin MI
Did you get an alignment done? Sounds like your alignment is off.
The coils on the radius arm trucks all come with a bow in them. Thats normal.
P
Popovic77
Ohio
Alignment was done it was the same before and after the alignment
mtnrider
Georgia
How much lift? Are you running wide offset wheels?
P
Popovic77
Ohio
6 inch lift 35x12.50r20 wheels -44 offset
mtnrider
Georgia
That offset is absolutely killing you for starters. Also that 6" lift is doing you no favors.
If your springs are bowed it's because they cannot get enough castor adjustment. Are you running aftermarket radius arms or drops?
Hate to say it but you are fighting a losing battle with that setup....
P
Popovic77
Ohio
They are drops and yeah that’s what I was thinking, still it was not wandering like it is before I did the ball joints toe bar and drag link
