1500 5.7 powered heated back center glass
Colt45321
Mims Fl
I had to bust out my center back glass and am wondering if anyone else has done this and if they were able to buy just the center part of the back windshield to replace and how to replace it. Or did you have to replace the whole back windshield. Dodge said they can do it but would also have to buy new window motor because the new window doesn’t work for the 2014 motor.
McBroom
Denison Tx
Hemi 6.4L
I have a full manual sliding rear window id be willing to part with. It's oem in the factory mopar box. Again it is Not a power slide
Black 20 Ram
C
Colt45321
Mims Fl
Thank you sir I wonder if I can use that one on the motor that’s in mine
GordDavey
Toronto, Ontario
I used to have a solid rear window. I put in a powered rear slider, window (wanted one with the heating wires, but couldn't find a junk yard one) and dealt with the switch in the overhead console and wiring to console and window for it myself. So, can be done. If you don't have the overhead console, then it too can be added. Just more wiring to be done.
Phxsparky12
