revitupmoto33
- Mar 11, 2018
- 875
- 1,741
- Location
- Flagstaff
- 2017
- Ecodiesel
Evidence of a good time!
You too man. If I had a half ton it’d be set up like yours.Evidence of a good time!
Sure is, I kept debating on what to use for the bar itself. Was torn between 1.25"x.120 chromoly tube or the 1.5"x.250 dom. Ended up going with the 1.5" just because it sounds like its way overkill.That's is one beefy TB
Looks good. I really need to make myself a tb.Painted the TB and installed along with 1.5 spacers on top of the 1.5 icon coils. Knowing I would need to use a spring compressor to get everything to squeeze in, I didn’t even disconnect anything other than that sway end links for the install. Went in without any issues. Got that 1.5 rake back. 39.5” front, 41 in the rear. Had to do some adjusting on the Tbar to get everything centered up again. Before and after pics.
Now you need extended sway bar linksPainted the TB and installed along with 1.5 spacers on top of the 1.5 icon coils. Knowing I would need to use a spring compressor to get everything to squeeze in, I didn’t even disconnect anything other than that sway end links for the install. Went in without any issues. Got that 1.5 rake back. 39.5” front, 41 in the rear. Had to do some adjusting on the Tbar to get everything centered up again. Before and after pics.
Don't you have a relo bracket ? or you want to beef up the stocker?Looks good. I really need to make myself a tb.
Sent from my SM-N920V using Tapatalk
Yes it's relocated, this stock rear is just super flimsy. Like you said you can flex it by hand, not too keen on it.Don't you have a relo bracket ? or you want to beef up the stocker?
I’ll send you the list of all the parts and where to get if you want.Looks good. I really need to make myself a tb.
Heims for the sway links have already been purchased and in transit. Maybe next week sometime.Now you need extended sway bar links
I was surprised how much difference that bar makes. Seems more solid back there now, or it’s all in my head. Either way I like it.Yes it's relocated, this stock rear is just super flimsy. Like you said you can flex it by hand, not too keen on it.
Wait until you throw the links too, she'll feel even better.I was surprised how much difference that bar makes. Seems more solid back there now, or it’s all in my head. Either way I like it.
Can't figure out how to double quote, if you could shoot me that list id much appreciate it.I was surprised how much difference that bar makes. Seems more solid back there now, or it’s all in my head. Either way I like it.
I'll get the list to you. There may be cheaper vendors for the heim joints but these guys are very reputable and their website is pretty user friendly.Can't figure out how to double quote, if you could shoot me that list id much appreciate it.
I'm sure that bar made a big difference, this stock one is embarrassing. I felt a huge difference when I was messing with my relocation and everything, so I'm sure that stiff bar made a huge difference.
Heims arrived way sooner than expected so built the upgraded sway bar links. Set them at +1.5”.
