revitupmoto33
- Joined
- Mar 11, 2018
- Posts
- 875
- Reaction score
- 1,741
- Location
- Flagstaff
- Ram Year
- 2017
- Engine
- Ecodiesel
Thanks buddyLooking good, Zach.
So new version tilts down and/or to the side ? Damn...![]()
Thank you sir. I’ll have to add up all the receipts for material and the time I spent on it to see if it would be worth making more of them.Please manufacture these. For all the sanity in the world there are so few aftermarket tire gate carriers for Rams. It’s disheartening.
Thanks buddy, it’s been a lot of trial and error.Amazing build thread. I am totally floored. You could make a mint on those water tanks alone. Great work!!
Did you ever get this finished?Got the new flexible 100w solar panel mounted to keep the auxiliary battery charged when the truck isn’t running. Layed down a sheet of white vinyl first to protect the paint then 10’ of 38lb gorilla double sided adhesive to secure it. Just waiting on the rest of the wiring to show up.
That I did. Just ran the wiring from the panel to my solar controller which feeds the aux battery. Have a REDARC smart start isolator between my starter battery and aux battery.Did you ever get this finished?
Do you keep the battery under the hood? Do you have any power ran to the bed?That I did. Just ran the wiring from the panel to my solar controller which feeds the aux battery. Have a REDARC smart start isolator between my starter battery and aux battery.
I used to have the aux battery under the hood where the oem air filter is located. However I didn't like the cone style air filter so switched back to oem and went with a Renogy AGM battery under the rear passenger seat. No power outlets in the bed, only power going back there is for the water pump.Do you keep the battery under the hood? Do you have any power ran to the bed?
