18" vs 20" wheel question
brihvac
Wilmington, DE
5.7 non e-torque
I am looking at a Big Horn with the basic looking 18" wheels. My question is you can buy the same truck with 20" wheels. So......
Is the speedometer set up differently between the 2 trucks so the mph is correct? Can you put 20" factory wheels on the 18" truck and the speedometer still be correct?
KG5TUD
Northwest Arkansas
My 2019 came with the 20" factory wheels
Sent from my SM-G988U using Tapatalk
RedneckHippy
Washington
2019 Ram 3500 Tradesman
6.4 Hemi w/ MDS
Your speedometer is going to depend on the overall diameter of the tire, so if it is different than your stock tire you’ll have to calibrate your speedometer. It is super easy to do, but if you’re within an inch or so of the original tire diameter I wouldn’t worry about it.
Ridgerunner665
US
As long as the tires are the same diameter... the hole in the middle doesn't matter.
Sent from my SM-G986U using Tapatalk
B
brihvac
Wilmington, DE
5.7 non e-torque
They also come with 18" factory wheels
That was my question. Is the 18" factory wheel and the 20" factory wheel the same overall diameter? The Big Horn can come with either so is the truck itself specifically programed for a 18" or 20"? Or are the dimensions the same and the truck programing for the speedometer are the same so you can run either factory wheel?
RedneckHippy
Washington
6.4 Hemi w/ MDS
If you buy a stock truck with either an 18 inch wheel or a 20 inch wheel the difference in overall tire diameters are likely negligible, so I wouldn’t worry about it. The wheel has nothing to do with how the truck is programmed. Like the other guy said, the hole in the middle of your tire has nothing to do with it, it is the overall diameter of your tire that matters. Just swap them, the truck doesn’t care.
Rp3412
