BlownGP
- Feb 10, 2013
- 6,141
- 1,694
- Location
- Houston/Baton Rouge
- 2018 RAM Harvest New Holland Blue
- 5.7
Wow, a lot of misinformation here about what a thermostat does.
First and foremost, a thermostat is going to be underutilized without a tune. The purpose of lowering your coolant temperature is to reduce your cylinder temperatures and reduce detonation caused by that. Basically lower coolant temps means you can run more timing safely, which means more power.
There' no misinformation posted. But most people are not going to adjust timing on a stock truck. So what's the point.
And I ran a 180 Tstat with no tune and still kept the temps low, just not as low with fans adjusted.
