1960 International R-190 4X4 build. DT360 / Eaton 6 speed / NP271 / F550 Frame
DILLIGAF
DILLIGAF
Canadian Forces
Canada
Got them Mad Max looking tow hooks sandblasted this morning. Now heading home to pull off the front subframe to weld in sleeves for the bolts.
Hopefully I can get this done in a day, Good thing my order of gummies came in, I'll down a few 100mg to help with the process and make the pain manageable :anitoof: :hat: :driver:
DILLIGAF
DILLIGAF
Canadian Forces
Canada
Coolant pipe and custom pipe mount day :hat:
Was able to figure out what length of flex hose I need. Unfortunately I have to wait until Wednesday to finish.
DILLIGAF
DILLIGAF
Canadian Forces
Canada
If you guys ever wondered if at 1.25 bushing I'll fit a 1.125 hole with a 20 ton press. It sure does :dogpile: :anitoof:
These 1961 leaf springs are now good for another 50y :birgits_tiredcoffee
DILLIGAF
DILLIGAF
Canadian Forces
Canada
Those old leafs gave me a free 3" drop :birgits_tiredcoffee :anitoof:
Hopefully when I put the fenders on tomorrow the wheels will be centered in the wheel well
I'd build some sort of bump stop to restrict their movement a bit,if you plan on driving it in the winter.
Old leaf springs are famous for breaking in cold weather.
Looking good though Ian.
DILLIGAF
DILLIGAF
Canadian Forces
Canada
I'm putting airbags on this, :birgits_tiredcoffee. Leaf springs will pretty much be for keeping the diff in place and saves me for building a 4 link front. Which would be a major headache due to the lack of room available.
DILLIGAF
DILLIGAF
Canadian Forces
Canada
Moving my leaf springs back 1" to center my front wheels . The ******* at ford welded the front leaf spring mount to the cross member mounts .so now I got to do a bunch of fabwork. Instead of just moving a couple of bolts.
You don't have one of these yet :Big Laugh: :Big Laugh::Big Laugh: 1200 original miles and only $3500 :cheers:
DILLIGAF
DILLIGAF
Canadian Forces
Canada
Just got a chub, I literally just landed from my Philippines trip and this pops up on my feeds.
DILLIGAF
DILLIGAF
Canadian Forces
Canada
Finally back at it today, I was hoping the garage goblins would of set my front leafs springs while I was on vacation in the Philippines. :dogpile:
But she's exactly how I left her.
DILLIGAF
DILLIGAF
Canadian Forces
Canada
Well I wasnt expecting this to be so expensive. :oops:
Unfortunately for me the DT360 gear driven pump pushes out 2400psi and the F550 Hydroboost is a 1500psi system.
But this is the last step before I can start my engine :cool:
DILLIGAF
DILLIGAF
Canadian Forces
Canada
Hell yeah, I can reuse the F550 shock mounts . This just saved me a ton of work.
And this is the oil pan at full drop. :peace:
I also just got my Tracking number for that custom T-case to Eaton 6 speed adapter .
No members online now.
bradstephens25
