Pale340
- May 7, 2020
- 7
- 0
- Location
- Huntsville, AL
- 2023, 1996
- 6.7, 5.9
Hey all I really need some help here. I am working on a 1983 D250 with the factory 318 and Thermoquad carburetor. I rebuilt the carburetor and cannot figure out where the vacuum choke assist line plugs into. This is the secondary vacuum choke pod that is on the rear drivers side of the carb. The primary vacuum choke, on the passenger side connects to the base plate vacuum port in the back. The driver's side choke does not hook to direct vacuum and I cannot figure out where it hooks too. It has to be some where on the manifold and it seems it would not be direct vacuum, because direct vacuum is pulling the choke open instantly. There should be a ported vacuum hook up somewhere and I just cannot find it. Any help would be greatly appreciated. Thanks.
