I have a 1995 Ram Van 318/Auto, 75K original miles with a weird Intermittent Start issue.
Van usually cranks & starts normally. But I will get an occasional no crank.
Symptoms are as follows:
Dash lights (check engine, etc.) come on when key is turned to on but will not crank when key is turned to start position.
Battery shows 12.75V.
Starter relay tests OK per dodge manual test
Neutral safety switch on tranny tests OK per dodge manual test
Battery terminals are clean & tight.
As temp falls below about 50 degrees problem gets progressively worse.
What am I dealing with?
Is the Starter relay (or the neutral safety switch) a temp sensitive device & showing the first signs of failure?
Any help is much appreciated.
