Nassini
I have a 2017 Ram 2500 Power Wagon 6.4L and have recently expereinced a crank no start issue that I can not figure out. I orginally thought it was the fuel pump relay and installed a bypass. This worked for several weeks and then started working intermittently. It is no longer working. Thinking it was a fuel pump issue, I dropped the tank and started testing the pump and the plug. When i hook the pump to an independent battery the pump works as it should. I tested the ohms on the pump and it is showing 0.9 ohms. I have 12 volts to the plug but once i hooked the pump to the multimeter and to the plug the voltage drops as soon as the key is turned on. I have tried this with the factory relay (tested good on scan tool) and with the bypass installed. I purchased a new pump so I could do some additional testing but i am getting the same results. Does anyone have any ideas what the issue could be or what to test next? I have searched google and multiple forums but I can't seem to find someone that is having similiar issues or if they had something similiar they did not reply with what caused/fixed the issue. Thank you in advance.
