1998 1500 V6 rough idle
Rbritt1268
Louisiana
3.6L V6
Hey all. New to the group.
Have a 1998 1500 with a 318 v6.
REALLY rough running like a cylinder is missing. Code shows missing on cylinder #2.
Plugs and wires have been changed.
Wondering what the next logical step might be.
Thanks in advance.
Bob
MADDOG
Living in a Firepit
6.4L HEMI
Welcome to the forum.
First, just so you know, a 318 cu. in. MOPAR engine is a V8.
So did you replace the cap and/or rotor? I'd advise looking at those two components plus do a compression test on cyl. #2.
Rbritt1268
Rbritt1268
Louisiana
3.6L V6
I stand corrected. It is the v6, 175hp.
This was my neighbors truck. He said I can have it if I can fix it. I believe he said he replaced the cap also but not the rotor.
Joe w.
Virginia
318 5.2l
After you do a compression check if you have good compression I would change out the #2 fuel injector. I had a miss fire on #8 cylinder years ago and it ended up being the fuel injector.
Rbritt1268
Rbritt1268
Louisiana
3.6L V6
Thanks Joe. I had thought about changing the fuel injector.
El Huapo
California Foothills, USA
2019 4X4 Warlock 1500 Classic DS w/3.55 LSD
V6 flex
Don't know how hard the job is but I wonder if you can just swap fuel injectors between cylinders for a test? If the problem moves with the injector, you got it. Might save buying a new one unnecessarily....
Steve58
