1998 Ram 1500 rear brakes
tr121336
Sumerduck, Virginia
5.9L - 360 cid
After axle bearings and wheel cylinders replacement, figured I would replace brake hardware and shoes. Ordered the “Wagner replacement” hardware. I then discovered that the hardware is the same on both sides as the parking brake cable comes in on the right side of the wheel area on both sides, so the star wheel is the same. I have looked at the factory service manual, chiltons and watched videos and none of them indicate the same as I see. Is this correct?
