1st Regeneration -
SpainHorse
Utah
Cummins
2017 Ram 3500 regenerated first time at 34,000 miles. No warning, nothing on the dash just ran like S$&T!. Thought the injection pump was failing , then remembered regeneration. Drove 30 miles at 20 to 30 MPH to keep rpms above 1500. After 10 minutes a message came on in the dash and the check engine light came on. Appears to have finished regenerating, but the check engine icon is still on after 6 starts and stops. Seems to accelerate OK but with more turbo lag than before. Ideas???????
superjoe83
Oregon City, OR
That was not your first regen, these trucks are programmed to do a regen about every 25 engine run hours, sounds like you have some other issues going on and should get the codes read
I highly doubtful that was your first regen cycle in 34K miles. A regen will happen quietly "in the background" while your driving and you didn't know it was happening. You'll notice the fuel economy will dip during a regen, you can also see them happen if you have something like Torque Pro app to watch the exhaust EGTs. Only time you'll see something on the dash concerning a regen is if there is or potentially a problem with it.
