2” lift suggestion
2r0a1m4
VA
I’m looking for a 2-2.5 inch suspension lift for a 2014 Ram 1500 (5.7, 4wd). It’s a daily driver that I occasionally use for hauling/towing and would like to maintain factory rake instead of leveling. Do you have any kits you can recommend?
MN97SCB
MN
I have the same question. I would like a 2 - 2 1/2 lift but maintain the rake. I have a 2014 Ram Bighorn 4x4 w/ 5.7 hemi. As above a daily driver with occasional hauling/trailer. I have read in spots that people use the Blisten 5100's to level, I am just not sure if that is all I would need to lift front and back.
Appreciate any input.
Nick@GotExhaust
Supporting Vendor
SC
I'll message you.
Eibach Pro kit is the best option to lift the front and rear properly and to maintain great ride comfort. 5100 struts will lift the front only but not the rear. You can not lift the truck with the 5100 shocks. You will want taller coil springs and then taller shocks to accommodate the taller coils
