2000 Ram Posi Lock Install... Now trans trouble!!
Powerlineman83
5.9 Cummins
Hey all, I'm having trouble with my 2000 Ram. It is a 4x4 with the 5.9 Cummins. Everything was fine except the 4x4 so i set to installing a 4x4 Posi Lock cable kit yesterday.
After install, 4x4 works great as it should. Problem being, now it shifts at approx 3000 rpm from 1st to 2nd and about the same from 2nd to 3rd. I capped off the vacuum feed off the vacuum tree in the engine bay as I was supposed to.... It was literally fine up until I did the cable install and I can't think of anything else I should have affected.
Any help is appreciated!
Power247
High Point, NC
6.4 HEMI
Wish I could help you out man. Hopefully one of the others will chime in soon.
#LineLife. Stay safe brother!
Greg
2012 | 2500 | CCLB | Custom MCC by Double R Diesel
ManBOOYA
