2002 5.9 Ram whirring noise
delmo777
Noise starts when accelerating andngets louder the faster I go, almost sounds like real bad road noise from tires. Anyone else have this issue?
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
Does the noise change when you let off the gas or slip the trans into neutral?
D
delmo777
When I let off the gas and decelerate the noise diminishes, it only makes it when moving, at 60 mph it is so loud I have to turn up radio to hear it
Redtruck-VA
Virginia
Are you leaking gear oil? Typically that sounds like a possible pinion bearing. If I remember correctly, noise on acceleration is the front bearing and noise on decal the rear pinion bearing. Usually when the front brg goes bad the seal will leak.
D
delmo777
The front short axle has a rip in the boot I found tonight and the rear end has a leak
Redtruck-VA
Virginia
Jack her up and put in gear to see if you can locate the noise. My guess is pinion bearing.
PCA4208
Albuquerque, New Mexico
My truck makes that mumming noise when going 65. I'm not leaking fluid, but greg is right. It may be a bearing. Check for play in the pinion on the axle.
KAKA
