2002 dodge ram 1500 4.7L
Josh2002
Mo
I have a 2002 dodge ram 1500 4.7L
I was trying to add refrigerant to my system and mistakenly send voltage through my signal wire(purple wire ) on the ac pressure switch and my truck shut off. It won’t start up now just turns over. I also don’t believe my injectors are getting power nor do I have pressure on my fuel line . The 5.5volts wire only has 1.7 volts All fuses and relays in the fuse box are good and have power to them . Can anyone tell me what I’ve done ?
RamRod37
2014 Ram 2500 HD 5.7 Hemi
Georgetown TN
the one time I done that doing testing it fried the ecm pcm ground circuit in the ecm I had to buy my customer A new ecm. not something you want to do but if you do its defiantly one thing you make damn sure it don't happen again. Not what you wanted to hear I know you may get lucky and do a 20 min battery disconnect but ground circuits in pcm/ecm are not normally protected from this so more that likely a new ecm/pcm is going to be the only fix.
J
Josh2002
Mo
Thanks a lot. I figured that’s what happen. What did you do to figure out that it was the pcm?
