2002 QC Center Console sub box *lots of pics
rex450se
Independence, MO
4.7L
I want to start off by saying I did this over the course of a few nights after the kids went to bed, so not as much time as I would like. I have also never carpeted a box before, last one I did for the trunk of my car I did in spray in bed liner, so take it easy on the carpeting job. That being said, here is what I came up with.
I removed the center seat and used the seat mounting brackets to bolt the box in place. So the first thing to do was to remove the center seat and get the dimensions for the mounting holes.
Next I drew up an idea of what I wanted and cut out the pieces and threw it together so I could put it in and see how it looked. I wanted it to have the sub firing downward so that it is protected and out of the way. I also wanted it to replace the lower portion of the seat and still use the back part of the seat on top of it since I like using the storage compartment and as an armrest.
When I was happy with how it fit and everything I did the final assembly. Since I only had a little bit of time each night I wanted to get it at least glued together so it could cure over the next couple of days while I finished it. I have heard that some sealants can release vapors harmful to the speakers surround while it cures, and while I don't know the truth in this, no reason to take a chance. Here it is all glued and screwed. I also added some polyfil to the inside of the box at this time. I think I went a little overboard on the screws though.
Next I started wrapping the box in a kind of velvet material. Unfortunately It was the closest color I could find. The rear seat brackets are at a slight angle going upwards towards the front so I knew I would have a second layer of MDF on the front brackets, so I used this as the place to put my seam. I really had no idea what I was doing with covering this box. And on one side I cut the fabric too close. This is the only part of the box I am not really happy with, but was at a loss for how to do it better. I will probably redo it soon since it isn't perfect. You can also see one set of bolts. I drilled a hole and sealed them in with Liquid Nail from the inside. So when I tighten the nut on it it should theoretically keep it sealed. For the piece for the front bracket I used tee nuts and screwed the bolts up into them.
R
rex450se
Independence, MO
4.7L
And here is the finished unloaded box.
Here it is ready to be installed.
And here are some of it installed.
If you have any questions feel free to ask. It went pretty smoothly and only really had one issue. I just centered the sub up between the 4 bolt holes. however, there are 6 bolts on the seat. The back bracket has 2 seats of bolts on each side and my method of centering the sub didn't take into account the additional size of these brackets. I had to cut off about 1 square inch of inside on the bracket to clear the subwoofer. Not too big of a deal, but it was an issue I had. I also added some rubber washers when I mounted it so I didn't have all of the vibrations going to the seats. In the end I am really happy how it turned out.
Victor
HKkid
Missouri
Looks good! Welcome to the club man! I as well only used two of the bolts on the back.
BlackedOutHemi
DFW, Texas
2012 & 2012
5.7L HEMI & 6.7L Cummins
Looks great. Better than I could've done. Haha. Never have had experience in that kind of stuff.
LB3711
Trumbull, CT
3.6L V6
Wow thats awesome. Good job
Sent from my Transformer TF101 using Tapatalk
TexasRammer
College Station, TX
looks good. and i know how you feel about the carpeting. I just made a sub box for under my rear seat, and tried to carpet it. It didnt come out terrible, but not as good as i wanted it to...
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
looks good
WhiteExpress
Midland, TX
Looks like a great build! I really like the overdoing it on the screws (I think I had 4 per side on my last build)
I'd call an upholstery shop and see what they'd want to cover it. I think with a professional cover this project would be epic.
quietpeen
2021 TRX
Hellcat
nice work, I had something similar to that in my 05....A guy made them and had them for sale on ebay....It was call a hotbox.
R
rex450se
Independence, MO
4.7L
Thanks for all the comments. I called an upholstery shop and while it was less than I was thinking it would be, it's more than I want to spend since I'm currently out of work. But I will certainly be doing it soon.
Victor
ramhunter9
P-Star Jeep Wrangler
Looking good , I also built one like that but mounted the amp under and the sub rear facing .
Rogan68
Lancaster, TX / Winchester, VA
6.7L Cummins G56 DRW 4WD
Great job! What's the width? My 2g truck, the armrest brackets are about 13.5" apart and bolt to the sides of the lower section.
per Tapatalk on my EVO
zack
pa
2004.5 packing the smarty
5.9 cummins ho
nice
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
man, I miss mine..........
TMFMK
