Sheerider93
Hey all I've been getting this code only recently P0522 for the oil pressure sensor. When I remote start the truck when it is completely cold I notice that the oil pressure gauge says it has no pressure at all and the check gauges light shows. I reset the battery yesterday due to some other ABS and speedo codes which worked but the oil pressure still wont read correctly. I reached down by the sensor and it is plugged in correctly. Anyone happen to know how to make sure the wires to the PCM are reading good and that the sensor is bad? Thanks
