Luis tucker
Does anybody else have a one wire oil pressure sensor? It looks like the second hole is plugged with a plastic clip and a single burgandy wire running to it .I called my auto store and there's are all two or three wire harness but I don't see any left over wire attached to the computer side or sensor side to indicate there should be a wire there that broke.plus an added ****uation my oil gauge needle doesn't go up and down when the key first turns after a fresh charge on the battery like the rest of the gauges.
