2004 ram
Hogdaddy
florida
2004 ram 1500 runs great idels great but when you get on the gas( Going down the road ) it goes to 4,000 RPMs & acts like a rev limiter.
Any info ? PS No code or light
MADDOG
Living in a Firepit
6.4L HEMI
Are you doing this in Park?
H
Hogdaddy
florida
No, Going down road. Only 105,000 miles. other than that Runs awesome
Thanks H/D
Oliver Closehauf
Cincinnati
2005 Laramie
Cummins 5.9
Can you add a little more detail?
How fast are you going when you get on the gas?
How much pedal are you giving it?
Is it smooth acceleration up to 4k where it starts to act up?
Have you done any work to the engine?
When was the last time the plugs were changed?
Any details you can provide will get you help faster.
Daw14
South Florida
A clogged cat will cause this , you can remove the upstream 02 sensors and see if it fixes the issue , if so you know .
Bills86e
tampa bay
5.7L Hemi Longbed
Camshaft position sensor (cheap on eBay) If it gets dirty you can't just clean it. It is faultily telling the ECM how much gas to send to the fuel injectors.
pass side of timing cover, easy to install.
Bills86e
Bill Knight
Picton, ON, K0K 2T0
I had the same thing happen the other day on way home from work, it acted like a misfire wouldn't rev past 4000 rpm. I pulled over shut the engine off. Waited a few moments and fired it back up. Drove home no issues. The next morning I had a misfire code on ignition coil D. I cleared the code and the truck has been running fine.
Daw14
South Florida
Probably should get your codes checked , are You familiar with the key trick ?
Raadz
