2005 1500 SLT Blinker Issues
Kamren
Alamosa, CO
Recently, my truck started having an issue where my left blinker stops working any time my brake, tail, or reverse lights come on. If I use just the blinker, then it's fine, but when I turn on any other light it goes out only in the back. The front continues working, but blinks quickly. I pulled the circuit board off and switched it to the passenger side, and when I used the passenger side on the driver, it had the same issue as the original. I believe it is probably an issue in the wiring or in the harness. Any ideas?
ChrisJM
Pa
I’m currently have the same fing issue and won’t pass inspection because of this problem any help would be greatly appreciated
Check for bad grounds
