The lightning bolt designates a problem with the Electronic Throttle Control system. My guess is there one thing causing all the issues.
Per the manual: Electronic Throttle Control (ETC) Light (5.7L Engines Only)
This light informs you of a problem with the
Electronic Throttle Control system. If a problem
is detected the light will come on while the
engine is running. If the light remains lit with
the engine running your vehicle will usually be driveable,
however, see your dealer for service as soon as possible.
If the light is flashing when the engine is running,
immediate service is required and you may experience
reduced performance, an elevated/rough idle or engine
stall and your vehicle may require towing. The light will
come on when the ignition is first turned on and remain
on briefly as a bulb check. If the light does not come on
during starting, have the system checked by an authorized
dealer.
Manifold Absolute Pressure Sensor Circuit High
Possible causes:
(K1) MAP SIGNAL CIRCUIT SHORTED TO BATTERY VOLTAGE
(K1) MAP SIGNAL CIRCUIT OPEN
(K1) MAP SIGNAL CIRCUIT SHORTED TO THE (F856) 5-VOLT SUPPLY CIRCUIT
(K900) SENSOR GROUND CIRCUIT OPEN
MAP SENSOR
PCM
INTAKE AIR TEMPERATURE SENSOR CIRCUIT HIGH
Possible causes:
(K21) IAT SIGNAL CIRCUIT SHORTED TO BATTERY VOLTAGE
(K21) IAT SIGNAL CIRCUIT OPEN
IAT SENSOR
PCM
ENGINE COOLANT TEMPERATURE SENSOR CIRCUIT HIGH
Possible causes:
(K2) ECT SIGNAL CIRCUIT SHORTED TO BATTERY VOLTAGE
(K2) ECT SIGNAL CIRCUIT OPEN
ECT SENSOR
PCM
