2006 dodge dual climate issue
06Gacumminsdually
Ga
5.9l Cummins
I have a 2006 dodge ram 3500 Laramie with a dual climate AC controller. I have my motor speed selector constantly blowing when shut off. I'm not sure how I can get it to select the speed I want but so far I've changed the resistor on the passenger side and tested a new Lower motor also with no luck. So max speed and the 2nd to last speed work but on the off, speed 1 and speed 2 it just blows faintly. Please help!
HemiLonestar
Navy Badge Coast Guard
MD
Does it make alot of noise but very little airflow? Or is airflow normal at full blast?
06Gacumminsdually
Ga
5.9l Cummins
Airflow is pretty normal but I know I'm also having an issue with the blend door. I would like to be able to shut off my ac or heat as I need to
HemiLonestar
MD
Just trying to figure out if you're having a recirc door issue as well.
06Gacumminsdually
Ga
5.9l Cummins
Everything works mostly just trying to get the blower to shut off when selected t
Agcat
