2006 Ram 1500 No start
jws123
nj
Picked up a 2006 ram 1500 4.7 150k 2 door 2wd lowest model crank windows ect. It does not start it was very low on oil almost none in it they said it just died on them turns over and sounds fine but doesnt even try to start good fuel pressure to rail. I plugged in my scanner and here are the codes i get.
Transmission control system Mil
u110z Lost communication with SCM steering control module can-c.
u0114 lost communication with Final drive control module.
u0ff4 u0ff3 u0ff2 refer to manual
Clearly some electrical issues going on here will any of these make it not run? All suggestions appreciated going to start tracing wires connectors ect I already checked fuses
jws123
jws123
nj
Truck runs on starting fluid injectors are not getting pulse?
jws123
jws123
nj
Found this disaster under the dash... looks like someone tried to maybe put a auto start and some other **** half assed.
jws123
jws123
nj
Got it running found 1 blown fuse I missed the motor is shot tho still have some codes for SCM and final drive will have to deal with it after I swap motor its a mess under the dash.
