2010 lift ?
Tboyd218
4.7 v8
Hey guys in lookin to lift my truck a little bit I've been looking at spacers and lifts I don't wana spend more then 1000$ I just want my truck to sit better I wana get 33s any suggestion ? Thanks for the help
T
Tboyd218
4.7 v8
Any brand suggestion or size ?
fastNugly
Toronto, ON
2012 Dodge Ram Sport CC
If all you want is to run 33's, they will fit without any level or lift.
But if you are looking for lets say 35's then you will need a minimum of 2.5" and the right offset rim or spacers for your current rims.
But there are many options and especially for $1000, any questions let me know and I can certainly extend the forum member discount over to you :gr_grin:
T
Tboyd218
4.7 v8
I'd like my truck to sit higher without blowing over a grand I'm thinking of going with a 2.5 or 3 in level then run 33s with rock start rims I just don't know what brand to go with as far as the level kit an tires
fastNugly
Toronto, ON
If you got a 4wd, I would do the Bilsteins 5100.
You get the added bonus of a more comfortable ride and the ability to level.
you can set them at either 2.1 or 2.5
33's on Rockstars will fit just fine.
Member and Moderator here names Quietpeen has this exact setup other than using Hell Bent steel spacers vs Bilsteins.
T
Tboyd218
4.7 v8
I've seen a couple level kits that level the front and also levels the back any suggestions on getting a front and back kit ?
fastNugly
Toronto, ON
There are kits that do this like the Rough Country 3.75" spacer/body lift combo, but it doesn't level you truck if you use the rear coil spacer. You'll still have the same forward rake. BUT your front and rear will be higher
Plus it wont look so good with 33's
If you are going with 33's, I would do a front level. IMO
raptor1797
Ohio
For under 1000.00 you can do a HBS level kit and a PA 3" body lift and run 35" on what ever wheel and tire combo you like. Providing you do all the work your self that is.
tommyguns
chicago
I have the hbs leveling kit with 285/70r17's no issue at all other then I want to go bigger lol
fastNugly
Toronto, ON
Exactly
Heck, you'd be in the $500 range doing it yourself.
OP, if you need a PA lift, I'd be happy to extend RF member pricing
Let me know
jbmb06
chester il
I am also running the hbs 2.5" leveling kit with 33x12.50/20's with a 0 offset and love it! If your not looking to go big I highly recommend the hbs level kit, it gives your truck a great stance, it actually makes it look like a truck
Sent from my Nexus 7 using Tapatalk 2
Rtrago89
Lancaster,PA
I just purchased a Supreme Suspension kit for my 2012 hemi, off of good old E-Bay for 204.00 shipped to door. 3.75" front and 2" rear. Wanna clear 35's
fastNugly
Toronto, ON
You will clear 35's
monettejb
2018 Hydro Blue Edition Ram 1500
Greenville, NC
You sure you wanna do that? I've read alot about the death wobble in 4wd with leveling kits in the 2" to 2.5" range. 3.75" might be alot, plus you may need shock extensions. When you add a spacer, your changing the angle of the CV's in the front. People complain an awful lot about vibrations.
monettejb
Greenville, NC
You will clear 35's
I was gonna go with the 2.5" level kit, but I think now Im going with the bilsteins. You think I can clear 35's with the setting at 2.1" and a 1.25 inch body lift? Seems like 2.5" causes problems for people here and there.
4x4Hemi
Edmonton, Alberta
you will.
i clear 35s with 2.5 level, just make sure your wheels are the right offset
fastNugly
Toronto, ON
Surprised I didnt pick up on that.....
Glad you did.
But he ^^ is correct!
2.5" is the max you want to do or run.
I thought I read somewhere that there was a body lift in that. Looks like I misread
you will.
What he said.
0 offset rims on 35" rubber will clear with 2.5" level
noraa73
