2010 Ram 1500 4x4 code P0876
Aking21
I have a 2010 Ram 1500 4x4 Big Horn with a little over 50K miles. I have gotten the P0876 a few different times. I replaced the pressure sensor with a new one and it seems to have work for about a month but then the other day it shuttered quickly and my RPM jumped up to around 2500 and stayed there. No lights came on at that time. The next day I started my truck and the light came on.. Seemed to shift fine. 2 days later light still on and it shifts fine through 1st, 2nd and 3rd but when I get around 55-70 mph, it just stays around that 2500 RPM range. Then today after lunch, its shifted fine again. I did check the fluid level about 10 days ago after I had been driving it for it to get warm and it was a little low so I did top it off. (this was about a week before the light came on again) I have read anywhere from check the wiring to these trannys are known for the solenoid packs needing replaced and that fixes the issue all together. I talked to the dealer about the solenoid packs and they are on back order currently which kind of tells me something. I have an appt for Friday the 25th to get it checked out but I don't know if I should have them go ahead and order the Solenoid pack so it is there or if it is ok to drive the truck assuming they don't have a simple fix when I get it checked out.
A
Aking21
Anyone have any advice? Just to give an update. Seems that it things have pretty well stayed the same. Shifts in low gears and reverse just fine. I have to get on the interstate to come to work and its right at 2500 RPM which traveling 70mph. It's like its not dropping into O/D. Luckily, I haven't felt the sudden shutter at all again so I feel it's got to be a sensor of some sort. I did request a build sheet from Dodge and it shows I have the 545RFE tranny.
Tach_tech
5.7L HEMI
You’ll need to put a pressure gauge on it and verify what the actual pressure is.
More than likely though it’s the solenoid pack.
