2011 1500 5.7 3.55 limited slip. Any done dif bearings???
Dusty
Rochester, New York
I forgot tk ask what do you mean by center shaft bearing?. I have one drive shaft and 2 u joints.
Is it a two-wheel drive?
Regards,
Dusty
2019 Ram 1500 Billet Silver Laramie Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33-gallon fuel tank, 18” wheels. Build Date: 3 June 2018. Now at 121612 miles.
Jeepwalker
WI
2012 Reg Cab, 4x4
When you get to it, put the rear up on jackstands, put it in N and see if you can rotate the drivehaft and listen.
Then remove the wheels, remove the rotors, and remove the rear of the driveshaft from the pinion. Then lift up on each axle to check for free-play. Rotate the pinion and feel for roughness. If you drop the diff fluid check for exessive shavings. Then look at all the gears inside for chips and discoloration.
Check the u-joints by hand. Observe the parking brakes inside the rotors.
On my truck there's a parking brake adjustment nut on a cable end about under the driver's side near the back of the cab. IDK about yours.
Also, check your truck's front wheel bearings. Jack up lower a-arm. wiggle the wheel with hands at the 6:00 & 12:00 positions...vigorously. Any play and the bearing is going. Rotate and feel for roughness.
Let us know what you find.
JBatSea
