Barryrey
Has anyone replaced their sunroof drain tubes on a 4th Gen RAM 2500. The right rear tube has been discontinued by Mopar, I did go ahead and order two of the the left rear ones, they look like they have pretty straight bends but before I started to tearing things apart I thought I would ask to see if anyone else has attempted the replacement and if so are they truly two different tubes for rear right and rear left. The front ones are the same part number for both right and left.
I did try to have the dealer fix the leak but they said they were too clogged and that the rears were no longer available, which I found to be only true for the right rear.
