2012 Dodge Ram door creak.
BlkRamRt
SoCal
HEMI 5.7
I notice mine on a hot day only.
Jaxyaks
White lithium grease, never had a ram that the doors didn't creak
Treburkulosis
Treburkulosis
Glorified Car Washer
Haslet, TX
My 2011's front doors both squeak, I've tried Fluid Film several times but it always comes right back. Definitely hinge/spring creak, not rubber related because it does it at half to full open. I'll have to try some atf or maybe some grease.
I highly suggest atf.
wannahdawg
Only the driver door or my crew cab creaks. It is very obnoxious. I've done the white lithium grease, RemOil, WD-40, and ATF...LG gets me about a week. Then I'm back to creaking. I'm thinking about just replacing the hinges.
GoldDot
I use the plain aluminum based Antisieze grease on hinges. Works great on noises and lasts a long time.
LB3711
Trumbull, CT
3.6L V6
passengers more than drivers door. I gave up trying to quiet it. Its the door catch part. The little wheel the rides the detent. It doesn't turn and rubs the part that it rides on.
Gunz86
Been using the Mooar grease and haven't had a door squeak yet besides the rear passenger weather strip that rubs a little and I just use armor all to quite that up.
misuracaf10
I had that problem too... I used bicycle chain lube and it held up pretty good, just happened to have it and figured it could do the job
