2012 Uconnect/Bluetooth Issue
SCARECROW860
Connecticut
I picked up my Truck a couple months ago, The bluetooth doesn't work.. I hit the phone button or the Uconnect button, on the radio or the wheel.. and it says its not available.. SOMETIMES it will start the pairing process and then at random points during the process it just cuts off.
Anybody have any ideas on what it may be.. I'm hoping its just a bad BT Module or something I can swap fairly cheap.. called local Ram dealer and they have the headunit available but at $450 i'd rather go for a new head unit and not a 10 year old outdated model.
jawzs2
South Jersey
What radio do have in the truck? There should be a three letter code on the lower right corner of the radio. One model radio had bluetooth built-in, others use an external module, which was optional. If installed, it is on the right side, above the right side kick panel, behind the glove box. You usually can pick up a used one on ebay for less then $100
SCARECROW860
SCARECROW860
Connecticut
the radio is the 430N RHB, there is a BT module behind the passenger lower dash. Guess ill have to look up the part number and do some digging.
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
Welcome ScareCrow860
There are several New Englanders & Jerseyites & Empire Staters on this forum
SCARECROW860
SCARECROW860
Connecticut
looks like the part I need is 82212159 Mobile Handsfree module.
found the complete kits for $300-$400 across Ebay and Amazon.. the module itself used is between $60-$80.. but then I need to have a dealer flash the Computer.. guess ill call the local dealer tomorrow and see what they will charge.
jawzs2
South Jersey
You won't need a dealer flash if you already have the module and you're just replacing it, only if you are adding it.
