2013 1500 Brake squeal
hanadarko
Milwaukee WI USA
I have seen several posts on the internet about brake squeal on these trucks after a few thousand miles. Well I have 12k miles on my 2013 and its actually getting worse.
First I think it was one wheel, now Im not sure anymore?!
But, bottom line...has anyone had any luck at the Stealerships getting this addressed and/or a fix that actually works more than a few trips around the block?
We all know it makes the truck sound like a beater going down the road. Its only on light/mild braking vs hard braking and I know the squeal comes from the pads vibrating (not the rotors) but....
I don't want to bother going to Dodge unless there is a proven fix out there or perhaps one in the works that someone knows about?
Thanks :word:
MADDOG
Living in a Firepit
6.4L HEMI
Two methods I have used to good effect for squeal are:
1. copper grease on the pad backing plates.
2. bedding the pads. there is a process for this and you can find it at the Tech Section on the Baer brakes website.
StoneDude76
West Chester,PA
I have a 14' Crew Cab and my brakes squeal as well. It comes and goes. It started with around 8,000 miles. It has actually gotten better. It used to do it whenever i braked but now its intermittent.
Steve58
