2013/2014 front differential differences
jthesby
Crockett, CA
Hey all, have 3.21s in my 2014 1500, have found a used 2013 front differential w/3.91 with only 7k miles on it. Am thinking/planning on doing the swap. Does anyone know if there were any changes between the two, or are they identical (other than the gears inside of course)? Thinking this is a swap that I can do. Then let the pro's take care of the rear.
gopackgo69
Tampa, FL
Hemi ****
The swap would be easy, evrything is the same, what would you do for the rear? Swap gears or another axel swap? Switching axels would be the cheapest route to go. Manufacturers havent changed their bolt patterns yet on the gears so you would need those redrilled and tapped. plus the install costs also.
