2013-2018 Gauge Cluster Disassembly
Danweis1
Tucson, AZ
Anyone on here ever take apart a gauge cluster, from a 2012-2018 Ram? The one with the 7” LCD screen. Trying to replace the LCD screen. Getting the cluster out of the truck is easy. Taking it apart seemingly isn’t. It looks like is should come apart easily; there are 10 click-over tabs around the perimeter. When they are all released, nothing will budge. Gentle prying with plastic tools won’t even move the cover at all. I’ve watched every video I can find, read every post here and on other forums, and nothing. Anyone?
Thanks
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
Thanks
The lens and mask comes off all as one piece and requires the use of several swedges to keep the clips open as you move around the cluster unclipping. It should pop off when the are released. Do you have a picture of the back of yours?
D
Danweis1
Tucson, AZ
I do have a picture of the back. Also a couple pics of the clips. I released all 10 clips with a spudger and put guitar picks under each one so they could not re-connect. After I had all 10 released, I pried gently in several places and nothing would budge at all. Not even a hint of looseness. Didn’t want to break anything so I gave up.
Thanks
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Thanks
Interesting, not sure what to tell you as it should be free with the clips being released.
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
I will say that if you break it the part you are unclipping is a replaceable part with a separate part number(s). It is called the "lens and mask" on parts sites.
D
Danweis1
Tucson, AZ
So I decided to go the replacement route. I found a cluster assembly from a one year newer truck than mine. It’s guaranteed for a year and the seller will program the correct mileage into it, which is a nice bonus if you don’t have alfaODB. After I get that in, I’ll be able the take the old one apart without fear of damage. I’ll post the results in a week or two.
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
That can be worth it, but AlfaOBD is worth it in my opinion. Especially when you get the itch for your next mod... seriously underpriced software IMO.
D
Danweis1
Tucson, AZ
Just an update for those of you who may be interested. I received an instrument cluster from a 2017 (one year newer than mine) RAM 1500. The correct milage was programmed in by the seller. It fit perfectly and it works perfectly. No more flashing LCD display and non-functioning oil pressure gauge. All in all a great success. The cluster is warranted for 1 year. The total cost was less than a mail-in repair which would have resulted in a 3-7 day wait with no instrument cluster, and no working truck.
Now I can take the old one apart without fear of breaking something. I will post the results here.
CGDave
Did you ever take the old cluster apart? I am trying to get mine apart on a 2015 and having same issue you had.
D
Danweis1
Tucson, AZ
No, sorry I have‘t. It’s still sitting in a corner. Now that the weather has cooled off, I can stand it in my shed, so I’ll tackle is soon.
