truckin151
Long time no see guys. Got a bit of an issue with my ac that I've been putting off for a while and need to finally tackle. The issue is with the blower motor and/or relay. I start the truck and the ac runs fine but by the time I get to work, even on high, the air is barely being blown out. This sounds horrible but smacking the motor just under the passenger side dash makes it instantly turn on and blow hard again....until I go over a bump, stop to quickly someone bumps under the dash etc, then it starts slowing down and and not working.
Would you think it's just the blower motor and something came lose? Or blower motor is going bad? Relay is going bad? Both? Need to order parts and trying to figure out if I need to replace everything or just one part. Or maybe I'm completely off on my diagnosis. What do you guys/gals think?
