Rotzilla
I got 1500 mi on half a tank of DEF, then I towed 400 mi and used the rest up. I was rather surprised by how much was consumed while towing.
I went to local truck stop to use DEF pump $2.69 gal. took 25 minutes to put in 4.5 gal. I could barley squeeze the handle and the pump pressure would shut it down.
While filling the DEF the neck pushed through the fender and ended up hanging underneath the bed. I had to crawl under and push it back through the hole, then had to hold it in place to keep it from pushing through again. PITA
Truck stop attendant says they make a magnet for opening the flapper that attaches to the nozzle, that of course they were out of. She said the manufactures are failing to install these in the new trucks. (skeptical)
Service dept re-glued (really glue?) the filler neck back in place. They were unable to add any DEF because it was already full, so they were unable to replicate my filling issues. The service dept did make a interesting point that they usually fill the DEF with a funnel and gallon jugs of DEF, not a pump, so they are doubting also that there is a fill flapper that needs to be opened.
I have to take it back in in a few weeks for them to re-check.
Anybody having similar issues?
