2013 RAM 1500 65RFE Line Pressure Sensor issues
20131500MSM
Modesto, CA
4.7L
Hello
I have a 2013 1500 i just paid off on 7/21, and i’ve been trying to diagnose an issue i’ve had with it since i installed a sonnax pressure booster.
The original pressure sensor started to leak, so i replaced it and installed a pressure booster from sonnax because i thought why not as it was only 50$, it didn’t work all too well and the shifts were very soft at start, it started to unlock the torque converter on upshift from 6 to 5th gear and just overall drove horribly, so i started wondering what was the issue. i took off the pressure sensor booster and just connected the pressure sensor to the main connector by itself and got a P0934 code, but when i reconnected the pressure booster i got no codes at all. and also, the code comes up IMMEDIATELY after the engine is fired on after clearing the code without the line pressure booster being there
i replaced the sensor with a power torque sensor from oreillys, i ordered a factory mopar OEM one but i don’t know when it’s gonna be in aw USPS is being stupid with its tracking
is the power torque sensor bad, or incompatible? i don’t see the harness being bad as it’s able to recognize the pressure booster and not set a code. just wondering, i’ve chosen to let the truck sit as i dont wanna damage the trans if it’s in good overall condition right now.
Sent from iPhone XS Max
Burla
2010 Hemi Reg Cab 4x4
They usual suspect with the rfe is the valve body and/or solenoid pack. It is one of the easier dyi projects.
Burla
