2013 Ram 1500 intermittent service shifter, no bus, no start, dash lights freaking out.
kozman16
Hey guys,
I am new on this forum, but I used it recently trying to diagnose my 2013 Ram 1500. I figured out the issue and I wanted to share my experience in hopes that it will help others.
Backstory:
We had a really wet/heavy snow and freezing temps the following night. The bottom half of the truck was packed with ice. The first thing that happened was a “service shifter” message. After that all hell broke loose with intermittent random messages and all dash lights blinking on and off. After parking the truck and turning it off, it acted like the battery was dead. The gauges would flicker but after 30 seconds the truck would come alive, flashing all the messages again. During this I could randomly start the truck/put it in gear. I thawed the truck out inside for 2 days, no change. I checked battery voltage and it was at 12.3v. Replaced the battery with no change.
After reading multiple forums, I started troubleshooting the “no bus” message. Hooked up the scanner and got 16 codes all related to loss of communication between modules. Checked for continuity between CAN+ and CAN- at the OBDII connector and got around 60 ohms, which is good. But when I checked from CAN- to ground I got ~190 ohms and from CAN+ to ground I got ~280 ohms. (Not sure what the correct values it should be.)
With the key on, I located the CAN (C) star connector under the dash on the drivers side and started disconnecting each module one by one until the dash started to act normal. Finally disconnecting the yellow/dark green wire connector stopped all the issues.
Looking into the wiring diagrams, turns out it’s the TMPS module. Checked continuity and found 90 ohms to ground on the (yellow) CAN- wire and OL on the (green) CAN+ wire. Disconnected the TPMS module and the wiring checked good between both connectors. I opened up the TPMS module and found the board shorted between the power/ground terminals due to corrosion. Most likely due to the ice/water intrusion.
I have aftermarket rims without tire pressure sensors installed so removing the module completely doesn’t bother me at all (except for having the tire pressure light on the dash). Funny enough, it never popped the fuse for the TPMS.
I am a licensed A&P Avionics technician, not certified in automotive. But performing simple continuity/voltage checks and reading the wire diagrams will help you diagnose your problems. I really hope this helps someone and saves a bunch of headaches/money.
poopsleeve
Detroit
6.7l
Electrical is my weak point. I do read most Electrical issues here because, well I have had lots of them with my rams past 30 years.
Nice work
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
Great info & troubleshooting to share!
PS:
This is another example of how the 2013 is unique vs other 2014-18 1500/2500 & 19-24 4th Gen 'classic' 1500 trucks b/c it has the separate TPMS module at the front bumper and separate RF Hub behind the back seat (like early 09-12's) and the later 14+ 4th Gen trucks have the TPMS integrated into the RF Hub behind the seat.
sigor
Colorado
6.7 cummins
Hey guys,
Backstory:
sigor
Colorado
6.7 cummins
Thank you for the post Kozman! I am struggling now with my "no bus" crazy dash lights for couple of weeks. Sometimes it starts some times it is not (shifter locks and not moving).
The problem started with closksrping showing ESP light and cruise control not engaging. The codes were Steering Wheel control module not communicating with Power train control module and some lost can bus connections. Then trailer power module started acting up just randomly lighting up and flickering. It last about a year and now its just all random lights on the dash and intermitten start conditions.
I have not started measuring resistance and ground issues but your statement that "I located the CAN (C) star connector under the dash on the drivers side and started disconnecting each module one by one" .... looks like may be a good start to rule out modules integrity. (the truck was flooded about 7 year ago and i had to replace a bunch of modules) but had no issues since and until this last 6 months or so. (TIPM and bunch of other modules were replaced long time ago).
anywho if you can describe where that "star connector under the dash" is located ? i seem to not remember anything that would have central connection point for different modules. (mine has every option to it ... lotsa modules )
thank you,
Igor
madtrucker2016
New York-Staten Island
3.0 Hurricane twin Turbo
Hey guys,
Backstory:
I have a complete brand new take off seat covers, arm, and head rest too, Gray OEM brand new. Let me know. 60-40 rear covers
