Raaammmathorn
So recently my 2013 Ram 2500 5.7 came up with a P1004 code (Short Runner Valve control performance) and so after taking it to the the dealer they recorded an SRV valve actuator failure and replaced the srv $301. Check light back on, returned to dealer and they said it needed an intake manifold which was on back order, but when it arrived and they installed it 2 weeks later, still a check engine light for p1004. They said they tested the srv, tested circuits and removed the throttle body to inspect the srv actuation. So they ordered a new pcm, programmed it and installed. Still a P1004 code $523. One more time to the dealer and got the last invoice (picture posted very bottom) $847. I feel like they’re just throwing parts at this truck at my expense and still haven’t, in fact, found a solution. Plus this star company they contacted, without seeing the vehicle just advised to replace the entire wiring harness? At 36,000 miles and this truck has always been well taken care of and garage kept? Any help or ideas would be greatly appreciated. Thank you
