2013 Uconnect 3.0 stereo upgrade to aftermarket.
Gtikid98
This past weekend a friend and i tackled putting in my sony 701hd. it wasnt the easiest job but it is possible for the ones out there that want to swap out the factory head. personally, to be able to never use the cd player in the bottom storage bin again made it all worth it. (pictures are garbage, actually a sunny day and all i had was my phone, sorry)
Since there are no kits available we had to rig up a mounting plate. First you have to cut out the stock bracket since the 3.0 unit is only single din
we just used tin snips on the bottome piece then rigged up the new cage in place
at the harness all i did was tap/soldered into the speaker lines, power/ground.IMAG0943_zps7c7416b4.jpg
I had an unused plug that i found the illumination off of by the climate plugs(just hanging free). voltage for the illumiation wire will vary from 2 to 11+ volts when you adjust the guage cluster knob. my truck has two lighter/accessory plugs up front, one constatant one key on. i soldered on to the one for key on for accessory. A multi-meter is your best friend on this job.
running the power is easy, just go through the grommet next to the brake booster
IMAG0940_zps94495eac.jpg.
I did the speakers as well
placed the crossovers under the dash
We ran a backup camera to the handle on the tailgate(guessing that is where the factory one sits from the convienent spot to put one.)
tied everything in behind the tail light
i fiberglassed my own box for a JL 10 W3v3 4ohm
just placed the amps under the seat, nothing crazy.
put the bluetooth mic up my the mirror and finished off the head unit by putting some flat black strips of plastic to fill out the opening with backing strips behind them.
there are two little gaps at the sides of the deck that arent noticable to anyone unless you point it out, but once a kit is made i will most likely swap it in.
we tried to tie in the factory usb cable but didnt have any luck so i just dropped one into the sliding bin under the climate controls. I placed the ipod connector in the glove box and used an xm kit since the factory plug is funky and we couldnt get it to connect to the aftermarket unit. just placed the new xm ant. under the dummy plate at the center of the dash.
All in all, i couldnt be happier with the system. it sounds amazing and looks pretty good for my taste. Not the easiest install but it is possible.
bigq
Thanks for posting that up, I have the same 3.0 factory setup. I am just not as adventurous as you so will probably wait for the kits to come out.
WOW man, good job. You might be the first DIY'er to have tackled this. I'm glad a got a 2012 though lol.
Batt4Christ
Clinton, Arkansas
If I may, I am curious about speakers, especially in the doors. What size are the stock ones? What kind of plug?
G
Gtikid98
thanks guys. the doors are 6x9's all around. i went with a 6.5 two-way system in the front so i could replace the small dash speakers with tweeters. i just used scoche(think thats the brand) speaker plates to change it up.
the plug is a standard factory two wire socket type(male/female). i just soldered jumpers to the new speakers to retain the factory clips.
2013-ram3500
Missouri
Cummins 6.7
Nice work!! That install looks very clean? Is the fiberglass bowl shape factory or did you make a resin mold out of the empty cavity to fit your application Very nice install
G
Gtikid98
i made a mold then cheated a bit and went to my cousins(boat builder) and used his chop gun to beef it up a bit :p That made short work of the Box. capped it with MDF and cleaned it all up. The box hits way too hard for my aging ears so i hardly turn the sub up lol.
If i did it again i wouldnt of rounded off the front edge, i would have made it more angled like the pocket. i just got ahead of myself and im nit-picking...it really doesnt bother me at all.
smiley87
Alaska
5.7l hemi
How did you figure out which speaker wires went to which door? Just hook them up and adjust settings for each pair of wires?
smiley87
Alaska
5.7l hemi
Did you just make the strips of plastic from cutting out of something else or can I buy strips of plastic that fit the opening?
jrsram1500
Will doing all that mess with factory warranty at all...?
gmzvip23
2k12
Man that looks good. Seems like you know what your doing. Looks like a pretty straigh install.Imo the oem radios is ugly.
Swatem
Really like the install. Is that just a standard double din cage you used in the dash?
~Chris
jrsram1500
Metra has finally come out with a install kit with wire harness for the 2013 Ram 1500 express.... Hell ya so over this stock stereo, only you can't order it through them only dealers that deal with them, so i went down to my local car audio place and showed them the site and the stock number and should be here some time this week.... Went to best buy and they had no clue what they were doing just a bunch of damn kids. You can go to the Metra Online | Welcome to Metra Auto Parts Online Warehouse web site and put in your year, make and model make sure when you click on select vehicle you put in RAM not DODGE..... here is the stock numbers and info if you need it..
INST99-6518B_web.pdfINST99-6518B_web.pdf
Stock No. 99-6518B
RAM 1500/2500/3500 Mount Kit
Product Details
ISO Mount Radio Provision
Painted Matte Black
Applications
2013-Up Ram 1500/2500/3500 w/o 8.4 Touchscreen
Wiring and Antenna Connections (Sold Separately)
XSVI-5523-NAV Chrysler Accessory Retention Harness
40-EU55 European Antenna Adapter (Single FAKRA)
Stock No. 99-6518B
Product Details
Painted Matte Black
Applications
INSTXSVI-6523-NAV_web.pdfINSTXSVI-6523-NAV_web.pdf
Stock No. XSVI-6523-NAV
Dodge/Ram 13-Up Wire Harness
Product Details
Provides Accessory (12-Volt 10-Amp)
Retains R.A.P. (Retained Accessory Power)
Used In Non-Amplified Systems
Provides NAV Outputs (Parking Brake Reverse And V.S.S.)
Prewired ASWC-1 Harness Included (ASWC-1 Not Included)
USB Updatable
Applications
Dodge Dart 13-Up without Screen Option
Ram 1500/2500/3500 13-Up without Screen Option
