2014 Adding CHMSL Help
Burns1200
London, Ont
Hey guys. I'm looking for some clarification on adding a Cargo Cam on my 2014 Laramie 1500 CC. I have the 8.4 w/ Nav and tailgate cam w/ rear park sense. I'm trying to read other posts/replies about this but am still confused. I purchased a cargo cam light today and am awaiting its arrival.
So just trying to get ready, I know I'll need the harness and already have AlphaOBD to activate it. But what else am I needing? And what pins do I need to replace/move? Should I go looking in the truck behind the radio and the brake light to find out?
Also, how will I be able to activate the camera? Will it be along the bottom of my radio or how does that work?
I can supply the VIN if needed to help.
Thanks for the help!
Mpgrimm2
Preferred Vendor
SC
2022 Ram 1500 (5th Gen)
5.7L
I'm still up. Sent you a message.
1st:
your 2014 8.4 radio (& all 13-15 RAx) will only support both cameras at the same time on SW version 17.11.x
If you're on v16.x or 17.43.x your out of luck. If you upgraded from v17.11 to 18.45.x it'may still work.
Your other option is to get a 16-18 ram 8.4 radio that supports both or get an aftermarket interface module from PAC, Customtronix, etc to support multiple camera inputs.
M² Mods.
B
Burns1200
London, Ont
After checking my radio this morning I'm in version 14. 05.x so is it possible to update to a certain version?
Mpgrimm2
Preferred Vendor
SC
5.7L
I assume you have a Canadian radio/truck?
Yes, if you can find someone that has the Canadian 17.11.x sw for the year and model of radio you have (ie 2014 RA4/VP4-CA?).
I'm fairly sure I don't have any Canadian SW.
M² Mods.
B
Burns1200
London, Ont
Wait so can I only use 17.11.x or Can I also use 18.45.x? Or does the 18.45.x have to be updated from the 17.11.x?
Mpgrimm2
Preferred Vendor
SC
5.7L
Go to 17.11.x first to get ability to have both cameras working at the same time. May want to stop here and get everything working before considering v18.x.
18.45.01 is supposed to fix Nov 3, 2019 GPS bug in the radios and may remove the ability to have both cameras work at same time but I don't know for sure. (Must be on 17.x for GPS update).
M² Mods.
Evguy1
Errington BC
2014 RAM1500
Cummins ISB 170
Did you figure this out?
I have the same unit and would like to add the cargo cam. Where did you get the camera and harness from?
B
Burns1200
London, Ont
Haven't figured anything out, probably just going to find a newer radio for cheap. I got my camera off a guy on Facebook and going to get the harness from Mike above.
Badams
Manitoba
I'm trying to figure out the same thing for my 14 Sport. I can tell you that on 18.45.x after enabling CHMSL camera options with AlphaOBD, I get the "cargo cam" button, however when I click it then it only shows my existing tailgate camera with no option to switch.
All videos I've seen show ability to switch between the two (though only get a blue screen when the camera is not hooked up).
Going to look into trying to downgrade my RA4 and see what happens
Ricks Ram
On the 13 to 15 radios they need to have been updated to the 17:11:07 firmware in order for the cargo cam and backup cam to both appear on the radio screen. All 13 to 15 trucks originally equipped with the 8.4 radio and the cargo cam displayed the backup camera in the rear view mirror and the cargo cam on radio screen. The 16 and 17 trucks show both on the radio. When the 17:11:07 version firmware was released it had a glitch that allowed the 13 to 15 radios to display them both on the radio screen like the 16 and up trucks. This was corrected with the next update 17:43:××. I have heard that if you update from the 17:11:07 directly to the 18:45:01 you will still keep the function but I have no first hand knowledge. If you upgraded to 18:45:01 from any firmware version other than 17:11:07 your most likely not going to be able to have them both display on the radio. I don't recommend going down in firmware versions. I have seen people brick radios when doing this. If you are unable to correct the issue you can install a 16 or 17 8.4 radio your backup cam/cargo cam should both display on the radio as long as you have enabled all the correct codes in your BCM.
Mpgrimm2
Preferred Vendor
SC
5.7L
What happens when you put the truck in reverse?
M² Mods.
Mpgrimm2
Preferred Vendor
SC
5.7L
With cargo cam turned on and putting it in reverse, the radio does not display the tailgate cam. Just remains on whatever screen it was on
Specifically... Without pressing any buttons/ie on regular radio screen.... Do you get a blue screen on the radio when in reverse?
M² Mods.
Badog77
Oregon
Hi. I have a 2014 3500 Laramie CC. My firmware version is 18.13.17. I am wanting to add chmsl with camera.. i have already used AlfaOBD to turn everything on for cargo camera. What do I need besides the camera. Thank you 20200802_205203.jpg
Mpgrimm2
Preferred Vendor
SC
5.7L
Responded in other thread.
M² Mods.
Orca
