2014 Dodge ram 1500 sport - Battery dead
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
I think you should spread that battery, make the hole large enough to be able to slide all the way down on the post, Do NOT hit on it to force it down.
Once it will slide down, lift it off & clean the post with the proper tool, that was posted earlier, then put the clamp back on the battery & snug it down, just enough so that you can't turn it on the post with your fingers.
First chance you can, buy a charger called a Battery Tender & use it.
If you still have issues with the battery going Low, then start doing your trouble shooting
start from the beginning & take it one step at a time
Good Luck
O
omnisap
Calgary
5.7 V8 Hemi
Thanks everyone for all the valuable tips. I got it fixed and new battery in place.
Lets see how many days this new Kirkland H7 battery lasts before the truck dies again.
yohannn
Ma
I know this is old thread but is the exact same thing that happened to me. I had parasitic draw as the cause. The f@$#ing hood light was on. As it appears, when in position it would be off but when the hood closed, the light falls off and stays on. Solution, remove light.
GTyankee
3.0 ecodiesel
A lot of vehicle owners don't realize, that each time that you Start the vehicle, you need to drive 7 to 10 miles, just to replace the charge used to start it
