2014 Door Lock Actuator
RichieW13
Thousand Oaks, CA
I have a 2014 Ram 1500 Quad Cab.
The driver's door lock actuator has gone bad.
I tried to replace it yesterday, but couldn't figure out how to remove the old one. Have any of you done this?
The top part of the actuator clips on to a "floppy" black plastic piece that's attached to the door. (see attached photo) I can't figure out how to disconnect it.
I have to work at it through the door. It looks like the actuator might come out with the plastic vapor seal, but I can't figure out how to remove that either. I removed all the bolts on the edge of the vapor seal (there are about 10 bolts). But that thing still doesn't come out. I can't figure out what holds it in.
https://imgur.com/a/TEmBP
RichieW13
RichieW13
Thousand Oaks, CA
In case anybody else is looking for the answer, I was able to replace my actuator.
It turns out the trick is to detach the window from its holder. (Which is not too difficult.)
Here is a thread that shows how to do it: http://www.ramforum.com/f75/how_removing_inner_door_panel_window-79539/
I didn't completely remove the glass, like in that thread. Instead, I just disconnected the clips, and then used some duct tape over the door frame to hold the window in place for the 5 minutes needed to replace the actuator.
brendo99
