2014 Install - Need Comments on My System Configuration
rpr
GA
2014 Ram Limited
I posted this over at diymobileaudio but thought I might also get some additional feedback here.
Here is my planned system configuration:
Components
DSP: Rockford 3SIXTY.3
Amps: Alpine PDXV9 (x2)
Front Speakers: Hertz HSK-165XL 2-ways
Front Mids: Hertz HL70
Rear Speakers: JL Audio C2-650X
Sub: JL Audio StealthBox (SB-D-QDRAM/10W3v3)
Sound Proofing (front & rear doors)
Things I'm still concerned about:
Full Active Configuration
I plan to go full active with the 3-way fronts, and run the rear fills directly off one of the amps as the DSP will not have enough outputs for everything (the DSP has 8 channels of output and I will have 9 speakers including the sub). However, I will lose fader functions this way. Obviously imaging and control over the 3-way fronts is most important. Not sure how best to do this.
Tweeter Placement
I'm told you can fit the aftermarket mids as well as the tweeters in the factory location for the 3" mids in the top corner of the dash. I think the mids will be fine there, but I'm concerned about the imaging with the tweeters reflecting off the windshield. I understand putting the tweeters in the sail panels is less than perfect as they are pointed down in this truck, but I'm thinking that will still be preferable to dealing with reflections off the windshield which will be impossible to control. I have no desire to try to fabricate custom pods for the A pillar. So, I'm leaning toward the sail panels for the tweeters.
Where to Grab the Inputs for the DSP
I'm also still concerned about picking up the input signals for the DSP downstream of the factory amp, but I guess there is still no way around this on the 2014 Rams. So I need to use the high level inputs into the DSP?
I do like loud (but clean and distortion free) music on occasion (I listen mostly to rock), so I have opted for very high sensitivity components up front (the woofer and tweeter are 93.5db, the mid is 91db).
Any thoughts on the components or above install strategy?
lizardking
2014 Ram 2500 Laramie
Cummins 6.7 "The real deal"
My tweeters fit fine in the a-pillars. Not sure what the deal is with everyone using the Sail panels.
R
rpr
GA
2014 Ram Limited
You mean with out modification, no pods?
Can you post pics?
lizardking
They sit perfectly flush! Granted you don't want to go too big.
lizardking
The following tweeters that I know sit flush and fit just fine are as follows
ScanSpeak Illuminators D and Ring version
Morel MT250, 230 23 and 22
Alpine SPX 17Pro Tweeters
A/D/S PX Concept.2
SEAS Prestige 27TFFNC/G
LPG 26NA
Vifa XT25SC90-04
Hertz ML 280
Rainbow lines Cal 27, 26 etc.. The 28 is too deep.
The depth of the tweeters shouldn't be more than 22-25mm.
lizardking
I would venture to say that most of the Focal line of tweeters minus the Tbe's will also fit since they are very thin tweeters. I would also say the Dynaudio MD102's will also fit.
lizardking
The hertz tweeter you mention will also fit with only a 19mm depth. Tiny little guys.
R
rpr
GA
2014 Ram Limited
Great info, thanks!
troutspinner
Gilbertsville, Pa
2019 Big Horn Crew Cab
For me, the sails cost $15 each to replace and the A pillars cost $145 each to replace.
I don't ever plan to trade my truck in or sell it but that's what I said about the last 10+ vehicles I owned ;) To get back to stock is cheaper.
Sail vs. A Pillar placement is roughly 6" different. Does 6" make a difference? That's what she said.
lizardking
A pillars are $40 each.
lizardking
WeRmopar.com
troutspinner
Gilbertsville, Pa
Thank lizardking. I must be looking for the wrong part number, they show it as $101.
I still have to order my sails or mirror trim rings just to have on hand but would like to pick up a set of these as well. I would not mind tinkering, maybe even get into some customization with fiberglass.
lizardking
For my 2014 I show $36. I will get the part numbers
lizardking
1DX49BD1AB. Left
1DX48BD1AB. Right
lizardking
I just picked up two and they landed last week.
Reticle918
