2014 Ram 1500 5.7 Engine Harness Replacement
James3117
Kentucky
Has anyone been through this? I am replacing my engine harness because the first owner of the truck decided to cut the ABS pig tails and god only knows what. Also ive been having problems with the 3 way coolant valve, i have replaced it twice. I figure its time to replace all the wiring in the engine compartment. I have the engine harness. According to the mopar websites it will fit my truck. 68206857AC The thing that scares me about it is the wire coloring sheme. I havent looked to see if its the same. Also i need the part number for the harness that goes from the 3 way coolant valve to the pcm. Theres a connector on that harness that plugs to the main engine harness. Thanks
Reticle918
