2014 ram 1500 8.4 screen upgrade no ac
05 hemi
greeley pa
hi everyone
I switched to a 8.4 inch screen upgrade bought the radio and wiring harness adapter. after the install I lost my ac and wont work on the #7 speed on the fan. I installed the resister that came with the kit only thing I did not install was the blower motor resister which every video I seen showed near the feet area of the passenger side but mine is not there to replace it. Im assuming thats why its not working but was curious if anyone else had this issue and where it would be located to put that last part in?
thanks in advanced
Robert15801
Herndon, vA
Cummins HO
Did you buy a new radio? Was it OEM? If aftermarket, I'd start with their technical support.
05 hemi
greeley pa
It is OEM it was bought off ebay out of a wrecked truck. the radio and everything else works fine just no ac
larsm85
Ky
Mine is doing the same thing did you figure out your problem
Ghstrdr95
