v7tech
Hello Ram Forum,
I created my account sometime in December of 2021 having encountered an EPS rack failure. I believe that some flash floods that I drove through may have been the culprit. At the time due to supply shortages my only option to obtain a replacement was a remanufactured unit by Cardone sold via PartsGeek. The rack got my truck up and running and it only lasted from December 2021 till June 2022.
Living in Cutler Bay Florida we experienced some insane flooding in June and I believe that somehow it compromised my remanufactured rack.
I sourced another rack locally bringing the total rack count to 3.
There was a minor discrepancy with one of the cv boots being torn. Didn't think much of it as the rack appeared to be in overall decent condition in the yard.
Upon getting it prepped to place in my truck the torn boot did have surface rust and dried lubricant that I took care of with a wire brush, and newly applied grease. After that the new boots went on along with the cv clamps and the truck was up and running again.
Sadly that was short lived as of Friday my third replacement rack decided to stop working again. I suspect that the area in which the boot was affected likely allowed water to get into the motor/circuit board based on the rust I found. Perhaps having driven the vehicle around didn't help however, I would not have been the wiser.
Since I have the prior Cardone rack on hand I decided to take it apart to poke around inside and sure enough it confirmed that it was indeed the water that damaged it. Having taken apart the motor cover, and PCB water actually poured out and there was visible rust forming along the seal, droplets of water on the PCB and other cables.
Both racks along the passenger side is where the motor sits, and in the exact center the PCB is located. My replacement rack from the junkyard has a torn passenger side boot and it had rust. Leading me to believe its possible that the unit itself may likely have water inside of it shorting things out.
I'm hoping that I can obtain another rack as this one came with a warranty.
These minor setbacks are quite frustrating and I hope that I can get everything sorted out.
