2014 RAM 1500 Express Crew Cab
ram1500rsm
ram1500rsm
Trabuco Canyon, CA
15 min later
Hi beams on, fog lights on
48424769727_d4caa57f47_h.jpgUntitled by RAM RSM, on Flickr
Hi beams + fogs + lightbar
48424769692_de77a7c71f_h.jpgUntitled by RAM RSM, on Flickr
I'll wait for the sunset to adjust the fogs and see how they look at night.
Goose_1327
Just wanted to know if you think flush mount pods would work recessed into the bumper?
ram1500rsm
ram1500rsm
Trabuco Canyon, CA
You'll have to open holes in the rubber fascia so in my case i wouldn't do them like that with this bumper, but i'd think everything is possible the rubber material is sturdy as heck though not something i'll do myself.
ram1500rsm
ram1500rsm
Trabuco Canyon, CA
The fog pods will do the job. Not the most perfect cutoff but damn i won't complaint for $100 and 15 min of my time to install them. Still way better than any other pod I’ve tried before and they don’t bother the oncoming traffic, something i wasn’t able to do before with conventional pod leds.
48428244122_236b489003_h.jpgUntitled by RAM RSM, on Flickr
joshuaeb09
Medina County, TX
Hell for $100 of Amazon I'd say that's a super clean cutoff compared to some of the stuff I've seen that claims to have a "DOT" fog pattern. If I wasn't so sold on the Baja Designs amber SAE I'd be giving those a shot when I do my fog light pod setup.
Goose_1327
Once home from the sandbox and installed I want to go flush mounted to replace my factory fogs. I enjoy the clean look but we will see how it turns out.
ram1500rsm
ram1500rsm
Trabuco Canyon, CA
Came back from our trip to California Eastern Sierras. Stunning views given the hot summer we're having here in Socal with temps ranging from 95-100F, over there we were anywhere between 36F at night to 75F during the middle of the day. :)
48524215646_d4c3ccc806_k.jpgUntitled by RAM RSM, on Flickr
48524373307_607533bfe7_k.jpgUntitled by RAM RSM, on Flickr
Little cold to get in June Lake water as it was windy as heck
48524223816_9f17749325_k.jpgUntitled by RAM RSM, on Flickr
But great temps for mountain biking i swear..
48524383482_1a1b6df85a_k.jpgUntitled by RAM RSM, on Flickr
48524219556_4839983ac7_k.jpgUntitled by RAM RSM, on Flickr
The new KO2's behave impeccably, on the way back i kept the speed around 68 and 70mph as i wanted to best the 16.5 MPG best ever i got with the Falkens in 315/70/17.
Finished the trip home with one gas tank and more likely an extra 50-60 miles (needle at 1/4 tank)
I'm impressed with the MPG considering my truck weights at least 500lbs more than stock (mods only), and for this trip i was loaded with an extra 500lbs of extra weight, (passengers and cargo) 4 cyl crap disabled in my tune, 30 PSI in the tires.
48524344467_d391687205_k.jpgUntitled by RAM RSM, on Flickr
hodge-xj
5.9 cummins
What kinda bike you hauling down the mountain on? I always wanted to get out and hit west coast stuff.
ram1500rsm
ram1500rsm
Trabuco Canyon, CA
ram1500rsm
ram1500rsm
Trabuco Canyon, CA
https://customsuspension.com/collec...dodge-1500-2009-2015-custom-rear-coils-2-lift
Stumbled across these looking at coil options. Might be worth a look.
Sent from my P00I using Tapatalk
Too bad they don't list the specs or anyting else that indicate if the thing has linear or progressive rates.
Also in your case you want loooong springs because of the shocks you have otherwise you'll have to strap them or run coil retainers. at 29.7" long, you literally have rear shocks for 5-6" lifts :)
hodge-xj
5.9 cummins
I know! Lol I'm kind of at an end pass for now. It functions as I need it. Rear came back up to 41" un loaded so I know these coils just don't like weight. Honestly I'm not running it hard enough to warrant a change right now. Ill consider my phase 1.5 done for now. It needs nothing honestly, I want everything.
ram1500rsm
ram1500rsm
Trabuco Canyon, CA
Made email contact one more time with Deaver springs today as i really want to pursue a spring that can hold the weight i have in the rear of my truck and still provide 1.5" lift.
With that said i had to spend some time chasing down what rear springs my truck came equipped with to provide that info to Deaver Springs so they can spec me new coil springs.
Looking in the Stevewhite site i found there are like 21-22 different rear springs options, some are the same but interchangable left and rigth given some codes, like ZRT, ZSU etc, etc.
My truck apparently came equiped like this
code ZPT right rear
code ZDT left rear
So then matching those codes to actual Mopar part#'s this is what i got
ZPT -- 68304489AA
ZDT -- 5154649AA
I hate there 2 springs lol because i threw away my stock coils and i have no idea what i had before and verify that info.
In any case i asked Deaver if they could spec progressive or linear rate springs for me. I'd prefer a linear rate cause it's a lot easier to understand how much i can add before i sag x amount of inches.
Icons are 19.25 free lenght+ 1" daystar spacer, im asking for the same 19.5" free lenght but harder rate spring, or maybe something in the 20.5" free lenght rate, linear than can keep some more weight than factory and that in the end ii'd like to maintain 1.5" lift after the 441lbs of weight i have in the bed/rear of the truck.
will see what happens next.
revitupmoto33
Flagstaff
Ecodiesel
code ZPT right rear
code ZDT left rear
ZPT -- 68304489AA
ZDT -- 5154649AA
Not sure if the part numbers or loads are the same as the ones that came on my qc. I’ll happily pass em your way to use as long as you need if they physically need a set. Also interested in what they come up with even though I told myself I’m done with the rear end unless I find a killer deal on some used 2.5 bypasses.
ram1500rsm
ram1500rsm
Trabuco Canyon, CA
Thanks a lot bro i'll wait for them to reply and see if they need anything else.
ram1500rsm
ram1500rsm
Trabuco Canyon, CA
Failed attempt at buying cheapy recovery traction boards lol
I swear i thought i was ordering something a lot more representative, sure i wasn't looking to pay Maxtraxx money but i didn't think they were going to be this small hahaha. I only paid $20 for them fackers with Amazon coupon so what that heck. I'll snatch something from Craiglist and keep these ones underderneath the rear seat anyways because i'm curious to see if at least they'll work for something.
How they looked in Amazon
https://www.amazon.com/RAMPAGE-PROD...PRODUCTS+7702&qid=1567035022&s=gateway&sr=8-3
To how they look in the ground
48638573713_3b2405aa1d_k.jpgUntitled by RAM RSM, on Flickr
At least they fold like lady **** pads hahahaha
48639069377_4240923c7d_k.jpgUntitled by RAM RSM, on Flickr
48639069422_e4216d5261_k.jpgUntitled by RAM RSM, on Flickr
ram1500rsm
ram1500rsm
Trabuco Canyon, CA
Fun stuff so people have an idea how 285/65/20's look side by with 37x12.5x17's :)
Love the 2500's look, maybe one day i'll have one of those beasts
At the Gym today.
48639238598_f9f98ad1a3_k.jpgUntitled by RAM RSM, on Flickr
48639238483_2e3a01f3a6_k.jpgUntitled by RAM RSM, on Flickr
48639238628_fc88667f5d_k.jpgUntitled by RAM RSM, on Flickr
48639238448_1ca64789e8_k.jpgUntitled by RAM RSM, on Flickr
48639585696_e8e8c4f167_k.jpgUntitled by RAM RSM, on Flickr
revitupmoto33
Flagstaff
Ecodiesel
:rotflmao:
Who knows they may just work in a pinch. I have used floor mats with success in the past.
Fatboy1989
