2014 ram 1500 rear rotor will not come off
gen4ram1500
Good morning, i am changing pad/rotors on my 2014 Ram 1500, i can not get the rear rotors off, i have beaten them with a dead blow and a sledge hammer and only got it to move a little bit. when i pull on the rotors i can feel a resistance. the only thing i can think of is that it is hanging up on the e-brake, does anyone know a trick or have any advice? thank you in advance.
14RAM1500BG
maryland
My e brake was rusted. I sprayed them from the back side with rust buster where the e cable hooks to the lever. There is a star wheel you can loosen to back off the shoes too. I kept spraying and working the e brake on and off until it broke loose. If you have no rust then backing off the shoes should do the trick.
WilliamS
Tampa FL
This! The ebrake shoes are embedded in a tad making it impossible.
SYKRAMMAN
Banned
Jersey shore
06 Mega
Loosen the parking brake shoes by using a flathead screwdriver at the rear bottom off backing plate, there’s a slot about 1/2” wide to get to the adjuster gear and back down the shoes. Then you should be able to get it off from back side with a sledge.
kad
Hudson Valley, NY
5.7L HEMI
Is this the same slot where cable attaches
No, the cable will be at the top on one side of the truck and the bottom on the other, the slot for the star adjuster is opposing it, i.e. on the side where the cable is at the top, the star wheel will be at the bottom and visa-versa. There should be a rubber plug in the adjuster hole.
-K
