2014 Ram HID Install - lots of pics!
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
Andy from Omaha came down to STL this past weekend to get a set of 50W HIDs in his headlights, and a set of 35W fogs. Took the opportunity to snap a few pics of where I stashed the parts!
HID details - heads for the '13+ Rams can be found here - 2013+ Dodge Ram HIDs and the Fogs can be found here - 2009+ Dodge Ram HIDs - for Fog lights
Pass side resistor mounting - wanted to put EVERYTHING in a spot where Andy could reach it, if he ever needed to.
Driver's side. Relay harness, resistor and ballast
Fog mounting. I really like these 13+s....remove the bolt on the lower mount of the fog, boom, ballast mount!
ran the 12v wires to the fuse box
All done!
BoldAdventure
Airstream, USA
Great detail. I can't imagine the beam disbursement with the HID's in the stock housing is even useful. But being the retrofit guy I'm sure you know this.
I'm a fan of HID's in fogs though because they make the best "SEE MY A$$ COMING DRL"
:favorites13:
kris319
Miami, FL
Looks good! I mounted all my ballast using zip ties and the resistors using 3m heat resistant (450°) double sided tape. For some reason making unnecessary holes in my vehicle gets under my skin lol
Sent from my SAMSUNG-SM-G900A using Tapatalk
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
:favorites13:
Of course I've ran on drop in HID, Mini projectors, FXRs, stock and everything in between.
Bottom line, are they the best for disbursement? No, its a halogen housing, yeah. ;) But, they will be far better than stock. Not all customers have the budget or desire for the projectors, which we know will focus the light better, etc.
ah, just a few little holes. ;)
WhiteExpress
Midland, TX
Looks great! Love that truck's color too!
When did the resistors get so BIG?!
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
a while ago, TRS came out with a more heavy duty setup. I love these things!
Knighthawk
I live in the greater OKC area
Looks Nice. Just finished my 2013 Sport HID upgrade about a month ago. I have read a couple of your posts now and they really helped. I took lots of pictures inside and out. I tried to run the cables in the neatest way I could and for the ballasts I used 3M tape and stuck them to the battery box on the drivers side and the inside of the pillar on the other side. I figured if I have a light problem I will most likely have to pull the light out any way.
phorrestphire
